Air-Con just stopped working. Help!
  • tobodestroyer
    • Dec 2005
    • 174
    Hi,
    My ABY Avant has had no problems at all in keeping me cool for the past couple of years but yesterday there was no marked cooling provided by the air-con. I press the button, the switch lights up and their is the feint whirring of a blower starting up but the drop in revs at tick-over plus the sound of a harder-working engine are missing. I've checked the fuses and all seems fine (please point me in the direction of the specific fuse).
    Any ideas where the problem may lie? Do I just need the system servicing?
  • S2-5speed
    • May 2009
    • 22
    Mine too!! light comes on but nothing happening..just as the summer starts..what are the chances..!! I have Just read a few of the threads on the forum,and seems to be pointing me towards a leak somewhere and regassing required after repair..do a search as this is the first aircon prob ive had..
    • trevithick
      • Apr 2009
      • 174
      Try that check yer gas?
      T
      The older I get the better I was.
      • denniselbows
        • 740
        yep a leak sounds like your problem the gas has escaped and the low pressure switch is stopping the clutch on the compressor enjaging. you can get small bottles of gas in halfords for a quick fix but a trip to the air con garage people is on the cards.
        never set your expectations to high that way you are never disapointed
        • s2driveruk
          • 12696
          low on gas....needs a recharge
          1992 3b S2 Coupe
          • johne
            • Apr 2007
            • 1406
            No. 1 most likely fault
            No. 2 most likely fault
            No. 3 most likely fault
            You've lost your gas!
            John
