Windows and Sunroof dont work
  • cartechnik
    • Apr 2004
    • 23
    Hi Guys I used to have sunroof and windows that opened and closed.
    Can anyone help on fuses or could it be ignition switch or relays.
    Need help Please
    1995 aby S2 coupe with 171000 km on clock as yet still standard
  • barbuckle
    • 3
    Relief Relay?
    Need help Please
    I have just experienced similar problems (ABY 1993) and it turned out to be a sticking relief relay. It also switches off indicators. wipers, etc while the starter motor is cranking the engine.
    It is in the fuse box (marked on the lid) - I took mine out and "bent the pins" a bit and it sprnag back to life (but I put a new one in since it is no doubt on the way out).
    • cartechnik
      • Apr 2004
      • 23
      Cheers I will pull and check today.
      • nigelm
        • 150
        No windows or sunroof
        Mine does this briefly intermittently and most often on scorchingly hot days (like yesterday). As my aircon works I haven't got round to investigating. Thanks for the tip to fix it.
        Nigel
        ABY coupe 1994
        • cartechnik
          • Apr 2004
          • 23
          It didnt work
          I pulled out the relay shook it a little bent out the prongs but that didnt do it.Every thing else works on the car but the windows and sunroof.
          Anyone know if are any other relays or fuses anywere.I have ordered another relay just in case it is it.
          • GandalfS6
            • 332
            • Country: South Africa
            There are a whole bunch of relays under the instrument cluster - you have to remove the driver side kick panel (3 small bolts) to get to it. If you have hassles I have the wiring diagrams - just give me a shout!
            1995 Silver S2 (ADU) Coupe
            2006 Porsche 997 Carrera S
            2006 Misano Red RS4
            2004 VW Touareg V8
            2007 Golf Mk1 Race Car
            2004 Mercedes Benz Vito 112CD
