Fuel Gauge or Fuel Computer????
  • als2
    • Jul 2009
    • 809
    Afetr a bit of reading and some helpful replies im guessing ive probaly got a sticky or faulty sender (guage is up then down etc etc).
    Problem im having is that the guage which seems to be relatively sedate and moving down slowly, when she gets to about quarter tank she suddenly read E and scares the S**t outa me!
    So queation is, when the gauge reads quarter, do i have a quarter tank or do i have as the comp says, E for Empty or EEEEKKKKK!!!
    A little reassurance til i get to the weekend would be apreciated. Thanks
    PS. beter to replace or mend the sender?????
    someone might have fiddled with your gauage previously as you can adjust the gauge range - i've got mine so it just reads E on the trip when the guage hits the red - you should still have about 10 litres left at that stage. HTH
    • als2
      • Jul 2009
      • 809
      yeah cant imagine why, its history is very well documented and cant see any reason for it but that doesnt mean anything!
      Just concerned the guage is reading quarter and im running on fumes!!!!!
      or more worrying, empty! lol
      • veneto rs2
        • Jun 2006
        • 1022
        • Country: Veneto
        Be careful about this.
        If your gauge was use to work properly in the past you might have a broken wire on the floater.
        It happen to me and the problem was this:
        At the end of the floater arm you have two bare copper wires that are connecting two sliders to a copper board with two tracks.
        the time and the thousands times these two wires bend and bend... got one them to broke, and the only moment that I had the two broken parts got in contact I had a proper reading on the dash gauge (circa half a tank....)
        I changed my floater..... but if the fault is this you can easily solder a new wire on the old one.
        Stefano
        P.S.
        Don't need to say that soldering job has to be done with the part outside the tank....
        http://www.audisportclub.com/
        • als2
          • Jul 2009
          • 809
          lol vento, yup think ill do the soldering in the house! did see a guy welding next to carging battery before! not pretty!
          Does anybody know where to pick up a sender unit for the Avant if its totally gubbed???
          • DEREKCO
            • Feb 2009
            • 435
            hello it could also be the contacts on the back of the computer i had loads of problems with mine dingo and fat audi 80 suggested to me to check the multi plug been no bother since i cleaned it just a thought
              just to add i recently had a problem with my fuel gauge not reading right - it was becasue I hadn't done the nuts up tight enough on the cluster when i put it back together after fitting the plasmas.
              • als2
                • Jul 2009
                • 809
                weird! its actually been better of late. Ive cleaned the MAF the ISV and replaced the PCV. these al seemed to hav made the gauge less iratic but still the other day it went a bit nuts when it got near quarter tank. think ill clean the contacts on the rear of the cluster. its coming out soon for some bulb replacement. ill let u know how it goes
