What Heavy Duty Avant Battery?
    I need the largest heaviest duty biggest AH and CCA rated battery possible that will fit an Avant and is going to be able to handle heavy duty electrical use in my car.
    Can folks recommend some batteries they have used and what is the biggest size battery that will fit?
    Is 280mm the biggest or will some of the 300mm batteries fit?
  • terrybullwon
    • Mar 2006
    • 8782
    A marine diesel battery?
    Chef
    • GazzaG60
      • 4133
      just got a new battery.
      bosch silver 750 crank amps. 80 quid from andre page. 45 quid cheaper than halfords
      • ericd
        • Nov 2003
        • 1240
        I thought you were a "yellow top" man ?
          I've got the smaller Yellow top.
          • Ducky
            • May 2006
            • 636
            I use an orange top Optima, don't think you could squeeze much else in an Avant as tis pretty tight in there, but perhaps a Red Top gel battery would suffice.
              Think i'll look into the CTEK charger before buying a new battery
              • ericd
                • Nov 2003
                • 1240
                get the 3600 and this addon for it http://cgi.ebay.co.uk/CTEK-MULTI-XS-...item1c0d702b33
