Juddering rear wiper
  • AndyP
    • 6049
    My rear windscreen wiper judders on the return stroke and refuses to park up properly. I've so far tried 3 sets of switches, 2 relays and I've checked the motor is OK by putting power to it directly. If you push the switch away from you to activate the washer, it works fine, as soon as ou release it to park up it cuts out and judders.
    Any suggestions? Have I really had 3 dodgy switches?
  • archiboy24
    • Sep 2003
    • 286
    Common problem. Check here for a fix:
    Ben
    Calgary, Alberta
    Canada
    1991 CQ e//S2 w/ RS2 spec 3B 20vt
    Panther Black Metallic
    www.moda-architecture.ca
    • s2_bo
      • Oct 2005
      • 6067
      Mine does the same..
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • denniselbows
        • 740
        most likely the contacts on the gear are dirty. the grease in there will have gone solid take the plate off from over the big gear and clean off the contact surface on the driven gear i had the same thing with my front one cleaned it up haven't had any problems since and that must be a year and a half ago.
        never set your expectations to high that way you are never disapointed
        • topsparky
          • Oct 2005
          • 2014
          try rain x and drive faster
          1. SHORT SHIFT KIT
          2. PORSCHE CAYENNE CALIPERS
          3. H & R SPRINGS
          4. BILSTEIN SHOXS
          5. NEW BUSHES AND HP2 STRUTS
          8. fmic fitted
          • AndyP
            • 6049
            http://home.audi20v.net/problems-a-s...ld-wipers.html
            Thanks for the link, I stripped the motor yesterday and the grease was all dried up and crusty. I cleaned it all out and replaced with new lithium grease and it works fine now
            • pixsaudisex2
              • Sep 2004
              • 3110
              I do this on my side window motors it also makes them work so much better although you have to be carefull when doing these.
              • AndyP
                • 6049
                Got the same problems again, I've stripped the motor again and regreased it but it didn't work this time. Is there anything else that can cause this, or do I need to llok for a replacement motor?
                • AndyP
                  • 6049
                  Problem cured by the fitment of a brand new motor unit purchased for 99p from Ebay
                    what is it with VAG wiper motors?!
                    My coupe one is ******ed again i'm just going to give up on it and smooth the tailgate over.
                    Rear wiper on the S4 has given up and my mate rang me yesterday about his rear wiper on his golf packed up
                    • Le S2 Audi
                      • Jul 2009
                      • 3805
                      Thats weird....
                      Ones on MK2 Golf's NEVER fail..... Any issues are with the wires that runs through the body to tailgate or relays.... I've stripped over 10 cars and they have all been original units and all work...
                      Never sold any other that to people who have filled in the hole...
                      Quality must have gone down over the years...
                      New S2 - S8 & RS2 -RS6 Keyrings
                      • mcandmar
                        • Apr 2004
                        • 5118
                        Never had to replace one, always come back to life with a good clean inside. As covered before the original grease has a consistency of toffee at this stage and plays havok with the contact tracks inside the motor. Usually they stop parking properly but can get bad enough that they return really slowly while driving at speed, or even stop all together mid sweep. Cold weather certainly wont help as the old greese gums it all up.
                        91CQ20v - Gone to a new home
                        93UR-S4 - The Magic Carpet
                        94S2Bus - The Emerald Express
                          going to try this and see if it helps. I have noticed my front wipers are slow as well, I'm sure the motor could do with a refresh.
