Reverse Light Wire Identification
  • tobodestroyer
    • Dec 2005
    • 174
    Hi,
    I'm trying to wire in a new 13pin socket onto my tow-bar. Everything is connected except for a feed to the reverse light. As I look in the rear compartment where the battery is located (it's an Avant) all connections are made into the loom behind the battery. Which of these wires is the one for the reverse lights? Can you help?
    Tobo
  • tobodestroyer
    • Dec 2005
    • 174
    Bump
    Anyone?
      Try this for starters on a 7-pin wiring socket - http://www.s2central.net/S2_Schematics/B/B100.PDF - doesn't include reverse lights...
      Look at http://www.s2central.net/S2_Schematics/C/C01-09.pdf
      You'll find reverse light feed at the red/blue wire on pin 3 of a black plug in the left side of boot area (T6b shown on track 102)
