HID battery usage
    HID battery usage
    I've noticed that if I drive my car during the day my voltage around the battery is close to 14 yet the moment I switch on my HID lights the voltage is dropping really low.
    Could this be an alternator fault?
  • s2driveruk
    • 12696
    what's 'really low' Jamo?
    1992 3b S2 Coupe
      Is that at idle or when driving / higher engine speed. It is possible that the load will drop the alternator voltage at idle but it will recover with a few revs.
        It's both idle and driving between 12-13 volts, it's affecting the battery charge. I've been doing mainly night driving and the battery isn't getting enough charge.
        • s2driveruk
          • 12696
          hmm, i seem to remember mine dipping the voltage a bit but not sure that far. Would go check but not in a position to start the car
          1992 3b S2 Coupe
          • irishs2
            • Apr 2009
            • 2455
            From my understanding the HIDs only have their max draw at startup, during operation they should be less current draw than standard bulbs. Have you tried the old bulbs to see if it gives same results which could point to maybe slipping or faulty alternator?
            Eric
            95 S2 Avant under rebuild.
            • Evilgoat76
              • Feb 2010
              • 278
              • Home: Canada Current: United Kingdom
              HIDs take a whack on startup but as stated above, the draw once started is very little. Time to warm up is very short. Does putting on any other big consumers do the same, EG rear demister.
              • Sonic
                • Jul 2006
                • 5514
                It'll be the amplifiers Jamo
                S2Forum.com Administrator
                • Fat Audi 80
                  • 10547
                  It will be the extra 0.3 litres of displacement....
                  The Perfectionist
                    It does yep, I know it's not the battery it's brand new and I had it tested yesterday
                    • s2driveruk
                      • 12696
                      check the condition of the key wires off the alternator....i happened to notice on mine that they were in poor condition with quite a few strands on the heaviest guage lead broken and guess that is doing nothing to help matters.
                      1992 3b S2 Coupe
                      • dest
                        • 4287
                        I checked mine, the gauge does'nt even move a tiny bit when turning the HIDs on
                        • johne
                          • Apr 2007
                          • 1406
                          I assume you're reading the voltage off the voltmeter in the auxilary panel - in which case it's not the true voltage at the battery. Mine did the same, turn on the lights and it drops a bit. It's because that voltmeter is reading the voltage at that bit of the wiring loom it's connected to and it's affected by the voltage drop in the loom when you turn the lights on.
                          I'll wager that if you measure the voltage actually at the battery terminals you'll find it barely changes when you turn your HIDs on.
                          If I'm wrong, you've got a poor earth somewhere between alternator, block, chassis and battery -ve and you can find it by putting a voltmeter across each of those earths and see if you have any voltage across them.
                          John
