Window washers??
  • Azman
    • 3205
    Window washers??
    Hi all,
    weirdly the windscreen washers seem to have stopped working although the headlight washer still works when lights on.......
    Is it a new pumpjobby??? Do they run off the same pump or different ones??
    Aaron
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • Flat on my back
    • Jan 2007
    • 2449
    Have you checked the pipes first?
    Carlos.
    • Azman
      • 3205
      Yup all on tight
      Dark Grey Avant
      RS2 FARB
      • andy10v
        • 5996
        Its different pumps, sit side by side at the bottom of the tank. Front wheel off and arch liner out and it should be accessible.
        Might want to pull the pipe out the jet in the bonnet just to confirm no water is getting that far, also check they are not on different circuits in the fuse box, don't imagine they would be though.
        Sold ABY-stock
        • Azman
          • 3205
          Cheers for that dude will have to do some more investiagtion then
          Dark Grey Avant
          RS2 FARB
          • Azman
            • 3205
            Been having this again for the past few months - last time it was sorted with a bit of a jiggle round in the stalk cluster, sorted the rear and front washer out. Now just done it again and got the rear back but this time no front windscreen washer, the light washers are working though. Next thing to check?
            Thoughts as it is nearly road gritting time and I done fancy not being able to see where I am going.
            Dark Grey Avant
            RS2 FARB
            • Christophski
              • 3632
              Try sqirting WD40 into the connections under the steering column cowel. Fixed my rear one when I did that.
              • Azman
                • 3205
                Cheers, done that matey - seems to be the copper connections in the housing itself - have to take the whole thing apart and clean it all out which is a very fiddly job, just got to sort the fronts to get it all done...... aargh
                Dark Grey Avant
                RS2 FARB
                • Bowlerwell
                  • 1052
                  I might have an old set of stalks if that'd be useful to you...?
                  John Bowlerwell
                  Electronic Engineer
                  Present:
                  Nogaro Blue RS2 - TOE
                  Previous:
                  Kingfisher Blue S2 - UAA
                  Volcano Black RS2 LHD - DEX
                  • johne
                    • Apr 2007
                    • 1406
                    The motors themselves sieze up very easily especially if not used. Given that you can get new motors for under £10, that may be the easiset way to go.
                    John
                    • Zoig
                      • Sep 2008
                      • 555
                      Does anyone know from what model i could get get the suitable mist/spray type nozzles for our cars?
