URS4 windows stuck
  • adam g
    • Feb 2007
    • 445
    URS4 windows stuck
    Hello, can someone please help with a problem with the windows and sunroof not working on my URS4. Combined with the knackered aircon it’s a very warm place to be on my way home from work after it has baked in the sun for 8 hours.
    They stopped working about 4 days ago momentarily, after opening and shutting doors and cycling the ignition they worked again long enough to shut them all. The next day they stopped working again and haven’t since.
    I have replaced the thermal fuses under the bonnet with standard fuses, no difference.
    Having read a few threads on this I understand it may be a relay problem, does anyone know where the relay is on a URS4.
  • adam g
    • Feb 2007
    • 445
    After much digging I found it to be the big relay in the panel behind the accelorator pedal. swapped it and all is working again.
    • saltinot
      • May 2004
      • 1946
      That bleepin' double relay! I grab all I can find at the breaker.
