There is a big relay under the steering wheel in the section for them normally a double size one with 363, there is also a small silver metal fuse above this with green on the top (20 amp fuse) that also works with this, check they are seated well and tap them as it may wake them up so to speak. Also you can try a normal 20 amp fuse instead of the metal one to see if thats shot, found another forum members s2 with the metal one replaced by a normal fuse
