One headlight (drivers side) has stopped working on dipped beam. High Beam still works on both lights and also the side lights both work. I have a HID kit fitted and thought the ballast or bulb might be at fault. I swapped the ballasts over and the same headlight still didn't work. I even tried new HID bulbs but no joy.
All connections looks good with no corrosion that i can see.
Is this a problem with broken wiring maybe as the loom comes across from the passenger side to the right / drivers side?
Does anyone have a wiring diagram for the lights?
