Anybody have an english schematic for the 3B fan wiring? I have brown, red with black trace and red with light blue trace wires on mine. I have a Pacet fan fitted and I'm currently using the brown and red/light blue which seems to be giving two speeds. Fast for when engine gets hot and slow for after run pump, so whats the other wire for?
3B engine fan wiring
There is only one place for wiring info...
Look like the red/blue is for the after run circuit and low speed fan, red/black is high speed fan.
I think the stock fan has a resistor built in on the red/blue connection, looks like a resistor to me in the diagram. There is also an external resistor shown (N47) from the after run circuit which would slow the fan down even more. Then the Red/Black dosent have any resistor in the circuit, hence full speed. I might be wrong but thats how i interpret it.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express -
hmm, interesting i get one speed and haven't heard it kick the after-run fan in. Will go check later if i get a mosigpic
1992 3b S2 CoupeComment
