injector data - EMERGENCY
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    thanks everybody for answers..
    well now I have aan injector in car with aan ECU (MTMsoftware) and I think that my car suck more gasoline than with 3b injector..
    if the engine are cold , and start them , few minutes at idle , when the engine is hot they get from me 0,4l of gasoline just for warm up.. is that normal on aan engines or I'm mad...
    can somebody tell my how is on his car...
    if I done 5 km at town they get 0,6l , we talk about normal drive... they sad to me 16.5 l/100 km is that normal..?
    when I have 3b injectors, the power was same , same speed .. but city drive was 12-13 l / 100km
    • prj
      • Mar 2010
      • 6308
      Your information is not very useful, and probably not very exact either.
      Verify with wideband...
      If you use 3B injectors instead of AAN with AAN software you will run richer.
      • jevrem
        • Feb 2007
        • 140
        • Country: Serbia
        This is the numbers that I find at a s-cars.org for aan and adu injectors
        AAN (black bodies) and ADU (green bodies) injectors are very different beasts...
        AAN injectors
        Run at 4.0 bar FPR in S4/S6
        Bosch 0 280 150 951
        Audi 034 906 031B
        280 cc/ min @ 3.0 bar
        315 cc/ min @ 3.8 bar
        323 cc/ min @ 4.0 bar
        361 cc/ min @ 5.0 bar
        ADU (RS2) Injectors
        Run at 3.8 bar FPR in RS2
        Bosch 0 280 150 984
        Audi 034 906 031F
        Porsche ?
        360 cc/ min @ 3.0 bar
        405 cc/ min @ 3.8 bar
        416 cc/ min @ 4.0 bar
        465 cc/ min @ 5.0 bar
        Audi URS4 1992. 2.2L 169kw
        www.audiclubserbia.com
        • rs200
          • May 2009
          • 1398
          • Home: Croatia
          yes this is a problem...
          I think that on AAN run richer than on 3B , how can it be...?
          now when I drive with aan injectors , now they want to kill me , how much fuel they need..
          you all will sad : what do you expect...?
          yes but not that big diference..
          • rs200
            • May 2009
            • 1398
            • Home: Croatia
            #20
            well I will order wide band AFR , but the postage from USA to Croatia is 133 dollars ... too much..
            it must wait for a little while ..
