urS6 Auto ECU & TCU Location
  • s2_wot
    • Aug 2006
    • 2178
    Right folks, I've got to remove the ECU from the S6 and I think it's in the passenger footwell somewhere close to that pesky afterrun relay. Anybody got specific directions and whats this about cutting the carpet to get it out??
    Also 'cos I have an autobox (slushbox) I have to find the TCU. Anybody got any ideas where that might be hiding?
    Steering wheel is on the proper side (RHD) if that makes any differance!
    Pictures etc to follow.
    Shane
  • spink
    • 4382
    yes the carpet needs slitting at the back of the centre console but theres a good chance its been done already,cant say i have ever had to do it on any c4 ive had ecus in and out of(quite a few),when you pull the carpet back you will see 2 black plastic panels,unsrew them and you will see the ecu
    box ecu is under rear seat i think
    • s2_wot
      • Aug 2006
      • 2178
      Thanks spink, so if you sit in the passenger seat, is the ecu in front of your feet or to the left or right?
      back seat is an easy job same as the s2 so happy days
      Shane
      • spink
        • 4382
        yes directly under the passengers feet
        part number is 4A0927156L for box ecu so you dont get confused with any other ecus under back seat
        • prj
          • Mar 2010
          • 6308
          Autobox ecu is not under the rear seat.
          Shane, I will PM you with pictures and details on how to do this before you rip your entire car apart, okay?
          • s2_wot
            • Aug 2006
            • 2178
            Thanks guys, open heart surgery starts tonight when I finish work.
            Shane
            • mcandmar
              • Apr 2004
              • 5118
              AFAIK Shane there both side by side under the passenger side carpet. Dont remember ever having to cut my carpet to get at the ECU but it is a fiddle to remove the plastic cover. Vacuum line to the ECU dosent have much slack in it either but apart from that its not a big job.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • prj
                • Mar 2010
                • 6308
                The carpet needs to be cut the first time.
                But honestly, I have not seen a car with an uncut carpet yet...
                Otherwise, yes, they are next to eachother.
                  Its fiddly at passenger side footwell if the carpet needs cut for access but no big deal.
                  I expect the comment about other controllers under rear seat of S4/S6 is that its a bit like S2 in this regard with boxes for ABS, difflock, airbags and all sorts of odd things depending on vintage and options.
                  Never had an S4/S6 automatic in my hands so interested to know where the TCU lives - though I suppose a quick search on the US based forums would find a result pretty quickly.
                  • s2_wot
                    • Aug 2006
                    • 2178
                    you haven't lived!!
                    Stanley knife, selection of screwdrivers and a hammer, what could go wrong?
                    Shane
                    • prj
                      • Mar 2010
                      • 6308
                      Paul, It's just above the engine ECU. A bit like the ECU location in the S2, but not shoved so much upwards, so it can be gotten out easier.
                      I explained everything to Shane, I believe he will make some pics and post them up
                      • s2_wot
                        • Aug 2006
                        • 2178
                        Shane
                        • s2_wot
                          • Aug 2006
                          • 2178
                          How to
                          Remove this sill thing and open the screws below it and move it to one side.
                          Then open the screw for this piece of trim and remove it.
                          Off topic:
                          This fancy looking red cable is going in the bin:
                          And this bit of electrical butchery is surely going to cause a headache some day:
                          Back on topic: My carpet was cut previously so the carpet was easy to pull down like this:
                          Under the carpet were 2 pieces of plastic. Neither were fixed to anything, so just sitting there. I'll need to look into that before I put it all back together.
                          Remove the pieces of plastic:
                          And reveal:
                          Move some wires out of the way and you see this.
                          The one with Motronic on it must be the ECU. The one above must be the TCU, the partnumber is very similar to spink's above.
                          I forgot to take any more shots but the 2 boxes disconnect from everything with relative ease.
                          Fair play to Dmitri who called me from Estonia to point out some of the above.
                          ps.. hammer not needed
                          Shane
                            Ahh not so bad then - well done.
                            • prj
                              • Mar 2010
                              • 6308
                              Btw, that plastic panel with a bunch of connectors in, it should be in place (you can find some bits there, so it slots in).
                              The two plastic panels are aligned. They both have holes and they go so that the large panel goes up and the small panel goes down, then there are some holes that need to be aligned, and if you look closely, there will be holes in the plastic below those two plates as well and some screw holes.
                              Well, now that you got those out, comes the fun part. Pray your ECU has sockets installed
