I had a few moments to experiment with this idea tonight and it works well... I'd post a pic but all you would see is a red light glowing in my fusebox as its well dark outside.
The idea is to get a simple visual indication that the fuel pump relay is activated. This verifies the ECU is happy that its getting rpm pulses from the G28 sensor at a suitable rate to activate the relay AND also that the relay contacts have energised for the pump and injectors. Its useless 99% of the time, when car runs well, but priceless when you have a no-start condition.
The tweak is the simple addition of an LED inside the relay and a small hole in the relay case to see the light when you have the lid off the fusebox. Its a simple enough mod for anyone with the knowhow and license to drive a soldering iron (and a drill), but if there is interest for me doing those for a small charge I could be persuaded.
The LED only lights when the ECU has activated the fuel pump... with the ignition on alone, the LED stays off. Pretty simple logic.
Paul
Paul
? I havent checked this out yet for my current no start/dead injectors problem. If so which relay contacts do what?
