I have an 91 coupe quattro and I wanted to put rs2 speedo and aux gauges in it. do i need a different wiring loom for it? or is it a straight swap?
rs2 speedo swap question
Tags: None
They'd go on fine, you may need to get the plugs from a b4 car (almost sure you will do, but easy to get from a b4 car in the breakers then solder them in) only other bits would be the under headlight trims, I doubt your car will have the individual ones more than likely will have one long one, cheap and easy to source. Then its just the grill as it will be seperate from the bonnet if its a b3 front, if so it will need extending to fit right or a b4 bonnet to make it look spot on.
Good luck
