Hi, a quick one: I need a fuse cover scan or so because I can't read mine and I not at home where I have a picture of it.
Rs2 fuses numbers and explanation
This is a sticky topic.
For some reason that I can't remember I scanned this in and cleaned it up when I bought the english fuse map for my S2. There was probably a good reason for it but I can't remember... Anyways... here's a piclair of it:
http://piclair.com/data/mlv6y.jpg
Windows might be under the steering wheel...
Originally posted by Billman View PostHi, a quick one: I need a fuse cover scan or so because I can't read mine and I not at home where I have a picture of it./NEO - I have a sexual thing for big brakes.
www.irry.com | Irry got a face lift!
#nordicaudi @ irc.nordicaudi.com
windows have a themal fuse under the tray that is below the steering wheel
see link
http://www.s2forum.com/forum/showthr...t=thermal+fuseABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
Probably a window relay, mine does that too, works for the most part, if it doesnt I just give it a tap on the side door and it gets working. There is as mentioned above a relay in the tray under the steering wheel (at least in the s2). Just has a couple of screws needed to get loose, a minor inconvenience though1996 S2 ABY Silver
