N75 cable issue
  • Billman
    • 4129
    N75 cable issue
    I have a problem with the n75 valve. I think the cable has a problem somewhere and it does not work all the time. I tried another valve and it behaved the same.
    How can it test it somehow stationary so I can look for the faulty place?
    Go Holset or Go RS4
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    well on the read cable must have +12v when the ignition is ON (or engine runing- dont remember).
    and thy yellow on cable is connected with ECU pin 33.
    • Billman
      • 4129
      I think the n75 cables are green and blue.
      Go Holset or Go RS4
      • rs200
        • May 2009
        • 1398
        • Home: Croatia
        maybe on S2..
        on my 200 20v and s6 are red and yellow. newer mind.. one must be +12v other on pin 33. you will see which it is...
        good luck !
          Originally posted by Billman
          I have a problem with the n75 valve. I think the cable has a problem somewhere and it does not work all the time. I tried another valve and it behaved the same. How can it test it somehow stationary so I can look for the faulty place?
          Try the ECU output tests, as described here:
          • Billman
            • 4129
            i have an aftermarket ECU but maybe i am gonna be able to test it while changing its settings.
            Go Holset or Go RS4
