Aan harness into 3B
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #61
    Sell this shi_t!
    • tajgreidotu
      • May 2008
      • 324
      • Country: Spain
      #62
      Originally posted by Rocco
      Sell this shi_t!
      Will take me 1 month to finish this, and to put all together, and you will be jelaous of my car
      • prj
        • Mar 2010
        • 6308
        With the amount of 2.2T he has... I don't think so
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          #64
          • hajbed
            • Jul 2006
            • 146
            • Country: France
            #65
            Are these the T6l and T6r ? ?
            I will see in my Type85 but as i remember this plugs are not necessary for the engine operation.
            These plugs seem to fit in the large dashbord and/or cooling system control (but not sure i have to remember or see my notes).
            • tajgreidotu
              • May 2008
              • 324
              • Country: Spain
              #66
              MERCI BEAUCOUP
              • tajgreidotu
                • May 2008
                • 324
                • Country: Spain
                #67
                What are this plugs for?
                ANY IDEA??
                • tajgreidotu
                  • May 2008
                  • 324
                  • Country: Spain
                  #68
                  Suposing that Im right naming as T6l and T6r the plugs above,
                  I had work on this a bit, I have made an excel, I think a good one that matches all the connectors from AAN with the Aby harness ones... Hope it helps:
                  • tajgreidotu
                    • May 2008
                    • 324
                    • Country: Spain
                    #69
                    In jpg:
                    edit: better in HIres
                    • tajgreidotu
                      • May 2008
                      • 324
                      • Country: Spain
                      #70
                      I got them!!! The black one is T6a, and the other, its for the immo, am I right?
                      • tajgreidotu
                        • May 2008
                        • 324
                        • Country: Spain
                        #71
                        Is some one reading me?
                        If I continue aswering to my own questions, I will go crazy! hehehehe
                        • tajgreidotu
                          • May 2008
                          • 324
                          • Country: Spain
                          #72
                          Wiring conversion done........
                          hope there are no errors.
                          Next step:
                          Try it and skip immo of the ecu
                          • prj
                            • Mar 2010
                            • 6308
                            What is the part number of your ECU?
                            • tajgreidotu
                              • May 2008
                              • 324
                              • Country: Spain
                              #74
                              4A0907551D
                              If Im not wrong, it has immo and also its from an automatic gearbox.....
                              I know I can short it by a chipped Ecu, but as my plans are going higher, I would like to skip immo and run it stock for a while, and in a few months, change turbo and.....
                              • tajgreidotu
                                • May 2008
                                • 324
                                • Country: Spain
                                #75
                                Good news, My new ecu has sockets!
