Engine died twice...
  • prj
    • Mar 2010
    • 6308
    Did you pull codes?
    You must do so.
    Possibly some trigger is giving problems.
    • Lloyd
      • Apr 2006
      • 1559
      Originally posted by irishs2
      Exact same thing happened mine. Turn ignition off, and on and on it starts right up. My error codes where showing intermittent short to ground on G40 (camshaft sensor). I have just changed it today and hopefully it sorts it.
      Hi IrishS2 - has your new Hall Sensor fixed your problem?
      RS2+ (now sold...)
      • irishs2
        • Apr 2009
        • 2455
        Without codes it will be hard to pinpoint what to replace.
        This might be worth a look , but I had codes to point me in a direction
        Eric
        95 S2 Avant under rebuild.
        • prj
          • Mar 2010
          • 6308
          Come on Lloyd, if you can root your S II, you can operate VAG-COM!
          Get a cable for 5 bucks
          • irishs2
            • Apr 2009
            • 2455
            Yes it did. In my case my g40 was failing and shorting to ground as opposed to open circuit, this is in my opinion what causes the engine to stop.
            Eric
            • Lloyd
              • Apr 2006
              • 1559
              #21
              @PRJ - yep, I would like to pull codes, I have a laptop, no software and no cable. Would you send me some links on a PM where I can get these please? I've not rooted it yet and may well end up bricking it!!
              @Irish - thanks, good to hear that worked for you. Having read up on your threads and the advice from others makes me feel a new Hall would work for me too.
              Has anyone got a spare Hall sensor kicking around from the recent forum Group Buy? I If so, I would like to buy it - please get in touch.
              RS2+ (now sold...)
              • prj
                • Mar 2010
                • 6308
                Our cars are old so the cheapest cable will work for you.
                Here are two example links, of what you need:
                http://www.ebay.co.uk/itm/2x2-2-Way-...ht_5519wt_1189
                http://www.ebay.co.uk/itm/Car-Diagno...ht_1977wt_1189
                I picked UK sellers, so it costs more than ordering directly from China, but it should be faster.
                Of course you can always shop around
                • Lloyd
                  • Apr 2006
                  • 1559
                  #23
                  Thanks, all ordered.
                  RS2+ (now sold...)
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #24
                    and after these cables and adapter, have we need to buy the Vagcom software?
                    i guy in Spain is offering me the 10.6 Vagcom software for 36€... and i am decided to ask first here before to buy anything.
                    will it work then?
                    thanks Dmitri
                      G40 Cam Shaft Sensor Info including PNs and DIY
                      ....Has anyone got a spare Hall sensor kicking around from the recent forum Group Buy? I If so, I would like to buy it - please get in touch.
                      Lloyd: When you get the G40 Hall sender, there is a link to a DIY by Nate P (ImQuattro) in this G40 info post:
                      • prj
                        • Mar 2010
                        • 6308
                        will it work then?
                        thanks Dmitri
                        Uhm, it is no point to buy that software.
                        VCDS 10.6 you can download for free on Ross-Tech's site but it will only work with a VCDS cable. The cable is what registers the software, the software can not work with an old style eBay cable anyway.
                        For these dumb mode cheap cables you can download this:
                        Of course if you want to have the full version you need to register your copy for 99 USD, but you can easily pull codes with the free version.
                        There are shadier means as well... as always, but no need to discuss that here.
                        • Lloyd
                          • Apr 2006
                          • 1559
                          #27
                          Thanks Dmitri.
                          Has anyone got a spare from the group buyI could buy?
                          I would happy to replace it asap, I juat cant get one before Weds for sensible money.
                          Stealers want £150 !!
                          RS2+ (now sold...)
                          • irishs2
                            • Apr 2009
                            • 2455
                            You might be able to get this direct from bosch and save a bit.
                            Audi part number 034 905 161
                            Bosch 0 232 101 020
                            Eric
                            • prj
                              • Mar 2010
                              • 6308
                              Replacing stuff without codes is just going to cost you money.
                              It might not even be the problem, that's the thing.
                              Is there no one close to you with a scanner who doesn't mind plugging it in for a few seconds?
                              • Lloyd
                                • Apr 2006
                                • 1559
                                #30
                                Agreed, gonna do my best to get the codes pulled asap.
                                RS2+ (now sold...)
