Ok, my 3B has had this full throttle misfire for ages now and its starting to chap my ****. Its only behaved properly once during a day out since ive had it. Usually this intermittent flutter/miss is there.
Its had Cap, rotor, plugs, timing belt, mark h mod no other leaks, maf connection carefully checked and cleaned, tried another used coil, and isv as the old one was scored inside. Temp sender on the back of the head appears to do its stuff ok.
I havn't replaced the ht leads yet its next on my growing list of to do's.
Plugged in with solus pro yesterday morning.
Camshaft position (hall) sensor *
(g40) open circuit/short with power intermittent.
Could a faulty hall sensor give these symptoms? Would it not just be start or non start?
Only ever had one non start - yesterday afternoon after checking bits, Third attempt it fired up. Not sure what id done. Still misses under heavy load fine otherwise.*
Any advice muchly appreciated, as its spoiling all the fun
Thanks.
Thanks.
so dont know the correct pin/wire location. Anyone have a pic of the plug from the back fitted to a switch?
ABY/ADU wiring "book" at:
