3b ECU fixing.
  • Quattro Dan.
    • Dec 2005
    • 746
    3b ECU fixing.
    It appears my 3b ecu is blowing one of the motor fuses, this happend while the battery was flat and i left the charger on fast charge while starting it. Does anyone know what would have blown? Or who could i send it to for repair?
    Thanks in advance,
    Dan.
  • prj
    • Mar 2010
    • 6308
    Thanks in advance,
    Dan.
    Pretty sure i know.
    You overvolted your entire car. Likely ecu is not the only thing that has gone...
    Ecu goes at 22V....
    I can try to fix it for you if you want...
    • caterpillar
      • 2480
      can be repaired in norway....
