Help needed with engine loom conectors knock sensor colours.
  • dirtybarry
    • Jun 2006
    • 282
    I have a 3b motor in my ur and just need to sort a couple of issues.
    1. Knock sensor colours.
    Sensor 1 @ the front is green, sensor 2 towards the gearbox end is blue (as pictured). Shouldn't these be green and brown? Also the conectors on the loom are blue and brown, Again shouldn't these be green and brown? I'm wanting to replace the knock sensors as the insulation has cracked. which one's should i get?
    1986 urquattro 20v 3b
  • dirtybarry
    • Jun 2006
    • 282
    2. Sensor on the top of the bell housing.
    As pictured below, what is this sensor with the 3 pin black plug and where does it plug into? I have no speedo working, has this got somethig to do with it?
    • dirtybarry
      • Jun 2006
      • 282
      3. Connectors near intercooler (ur).
      There are 4 single connectors near the drivers chassie leg as pictured below. 1 red 1 blue 1 white 1 yellow. White and yellow are for the stater motor, what are the red and blue one's for?
      • dirtybarry
        • Jun 2006
        • 282
        4. Connectors?
        Anyone have any idea what this connectors do and where they plug into?
        • Bowlerwell
          • 1052
          2nd pic of "connector 4" looks like the cruise control connector to the vacuum pump...
          John Bowlerwell
          Electronic Engineer
          Present:
          Nogaro Blue RS2 - TOE
          Previous:
          Kingfisher Blue S2 - UAA
          Volcano Black RS2 LHD - DEX
          • dirtybarry
            • Jun 2006
            • 282
            5. Oil sensor.
            What cable goes to this sensor and what sensor is this, Oil temp or level? Also where can i get a new one and whats the part number?
              3B and AAN Knock sensor info
              Originally posted by dirtybarry
              I have a 3b motor in my ur and just need to sort a couple of issues. 1. Knock sensor colours. Sensor 1 @ the front is green, sensor 2 towards the gearbox end is blue (as pictured).
              Somebody might have installed a AAN harness and/or AAN knock sensors. Actual 3B knock sensors are green and brown. The shorter one, 740 mm long, 054905377A, (Item 30 in the diagram), presumably the one closest to the rear of the engine is green for a 3B. The longer one, 930 mm long, 077905377A, (Item 31 in the diagram), presumably closest to the front of the engine, is brown for the 3B and ABY.
              AAN knock sensors are blue and green.
              • dirtybarry
                • Jun 2006
                • 282
                Sounds like I should go for new green and brown knock sensors then as the motor is 3b, Just hope they work with the brown and blue connectors on the harness. My harness seams to be a mix of 3b and aan for some reason.
                  You do know there is no electrical difference between the knock sensors? the colour only signfies the difference in lead length
                  • dirtybarry
                    • Jun 2006
                    • 282
                    No i didn't, thanks for letting me know, thats question number 1 sorted
                      More importantly, the colour is supposed to help you from muffing up the connections and connecting Knock Sensor 1 to the Knock Sensor 2 ECU harness plug and vice versa.
                        5. Oil sensor. What cable goes to this sensor and what sensor is this, Oil temp or level? Also where can i get a new one and whats the part number?
                        Not the best photo going so I am only guessing that it is the oil temperature sender that is located in the in oil pump, at the front of the engine, near the crank sprocket. Should be a single wire connection. http://forums.quattroworld.com/s4s6/msgs/93029.phtml
                        Original un-annotated photos were from 4WheelDrifter (Stu)
                        • dirtybarry
                          • Jun 2006
                          • 282
                          That is the sensor in question 5.
                          So it's an oil temp sender. I'm wondering if the wiring for this is one of the connectors in picture 3. I take it this will be why I have the oil warning light lite on the dash. Again thanks for the info, keep it comming.
                            Oil pressure switch and sender info
                            That is the sensor in question 5. So it's an oil temp sender. I'm wondering if the wiring for this is one of the connectors in picture 3. I take it this will be why I have the oil warning light lite on the dash. Again thanks for the info, keep it comming.
                            Those connectors in Photo 3 aren't for the oil temp sender. The oil temp sender is a single wire with a female connector that slides over the end of the oil temp sender, from the side, not the top. (sounds "dirty" I know).
                            BTW there is no oil level sensor, just oil temp and oil pressure.
                            • dirtybarry
                              • Jun 2006
                              • 282
                              Thats a great help thanks. Just need info on pic's 2 3 and 4 now.
