HID K pin info
  • Paulgo
    • Jan 2005
    • 498
    HID K pin info
    Now that I'm using the HIDs a lot more as its winter, the intermittent autocheck bulb warnings are really doing my head in!
    I've read about snapping off the K pin in the autocheck relay - does anyone have any pics or diagrams of what it looks like - not managed to find any so far - as I don't want to snap the wrong bit off! (I've a 3b in case there's a difference)
    cheers
    Paul
    Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
    Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
  • Paulgo
    • Jan 2005
    • 498
    Ah - when I pulled the relay marked 281 the K pin on the corner is quite obviously marked (as can be seen in the bottom left hand corner of the pic for future reference)!! .
    Hopefully this will sort the autocheck issues!
    • rotoryboy
      • May 2004
      • 3281
      Hmmmm, I wonder why it is called the 'K' pin
      Mark
      Race Clio RS197
      S2 Coupe ABY (Green) - RIP
      S2 Coupe ABY (Blue) - Sold
      • Paulgo
        • Jan 2005
        • 498
        At least I got there before having it (the bleedin obvious!) pointed out to me, as usually happens!!
        • Jas11n
          • 5067
          If you'd asked, I have two already modded and ready to go that you could have had for nowt.
          No good to me now
          2001 Avus Silver B5 RS4.
          1995 S2 Coupe - sold (sniff)
          • Paulgo
            • Jan 2005
            • 498
            I did but you were too busy buffing up the RS4 Really did only take a couple of mins, if I've done it right! Hardest bit was getting the booger out from under the dash and through the usual three plates of spaghetti (if you look closely as the pic you can see i managed to bend one of the pins!! )
            • Jas11n
              • 5067
              Buffing? in this weather?
              Nah, quick wash of the A4 before I lost all feeling in my hands and feet
