Now the cold/wet weather is here i use the air con to try and demist the inside of the car. On a recent trip the air con wouldnt work (it was to cold) i found out that at 7-8 degrees it started to work again, not much use as the temperatues sometimes dont get that high in the winter. Has anyone else experinced this?
The sensor for the external temp gauge is situated at the front of the car, is this used to gauge temperature to stop the air con working?? My mates car has got air con (not working) but no temp display (its an early car "h" reg) so im thinking not.
Is there any way i can make the air con work at lower temperatures? its brilliant at demisting.
