audi 90 with 3.6 v8 pt engine does not throw a spark on spark plugs help
  • meanicar
    • Apr 2011
    • 7
    • Country: Serbia
    healthy if we can help someone not normally ask for how long and trying different things that I'd got a spark audi 90 ng kuattro 87godiste engine and I was bored so I took the engine from the Audi V8 3.6 pt 250 hp with him and I took the motor current and ecu and do everything to throw up and running will not spark the spark plugs at one point i managed to get a spark and that was it then it began to happen something that no one can explain to me just throw a spark at the end when you release the ignition key and now it will not really mad but I invested a lot of nerves and I have motivation to finish it but when no one wants to i can not help me to do it on the internet i have seen more of these modifications, and all i have asked only those who have it all as and no I did not answer my question I would be very grateful if someone helped you colleagues
  • WabTheKing
    • May 2004
    • 2567
    Can you read diagnostic codes?
    • meanicar
      • Apr 2011
      • 7
      • Country: Serbia
      I have not tried it because I did not join the merged diagnostic extracts from the ECU to the connector for the diagnosis of a doubt that I merged all the wires that you need if you have a scheme or ecu pinout for this engine would be of great help and only for a few days I will be able to try with diagnostics to see
      • martinws
        • Oct 2008
        • 917
        Im not sure about this engine but i had a similar thing where i could turn the engine over but would get no spark but as soon i i turned the ignition on i would get one single spark. It turned out i has swapped the wires round on the hall sensor on the distributor by mistake. The engine was a 2l 8v from a B3 coupe though.
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Look here!
          Hope it helps!
          • meanicar
            • Apr 2011
            • 7
            • Country: Serbia
            I looked there and I connected on this pinout and it's not good, so I do not know what to do it more if you have a link to the pinout for the ecu I would be grateful
