Afternoon does anybody know which loom the afterun plug is on, im thinking its the one with the knock sensors but not sure anybody?
after run connecting plug
Ummm..and a few other things. Here is a diagram of the AAN Engine Bay harness. The after run switch plug is Item 24. The after-run ("additional water") pump is right beside it. Its connector is the Item 11 plug just under the pump. Should be similar for a 3B or ABY.
94 UrS4 V8 6 spd manual avant -
Cheers matey
