my fuel gauge is not moving anymore.. and it display less then i have benzine on the car and today its not working anymore what is the problem :$ is it the instrument cluster? or ithe fault from the sending unit which located in the reserv of fuel?
What does your board computer tell about KMs left? If it tells reasonable values then the problem is probably the gauge itself. If not, the sender in the tank or wiring problem (or instrument cluster PCB problem).
