Rev Counter Needle not stable
  • Tonybolony
    • Dec 2011
    • 636
    Evening All,
    Any suggestions?
    Holding a constant(ish) 80 on motorway, after a few mins, the needle starts moving between 3000 and 4000rpm. No other apparent symptoms.
    Is this a common one, or am I the only one to have this problem?
    Thanks.
    Tony.
  • s2driveruk
    • 12696
    never heard of that before....faulty gearbox sender?
    1992 3b S2 Coupe
    • Tonybolony
      • Dec 2011
      • 636
      Gearbox sender? For the rev counter? Surely it would be on the flywheel, or cam pulley? The speedo reading is constant, BTW.
      • Bullysteeth
        • Jan 2012
        • 830
        does the rev counter hold still at other revs (below 3 and above 4)
        • Tonybolony
          • Dec 2011
          • 636
          That's the strange part about it - at all other speeds up to 80 the needle is constant.
          Not been on an Autobahn, so can't tell if it happens at 150mph
          • Bullysteeth
            • Jan 2012
            • 830
            150 i wouln't dare
            • Colesy
              • Feb 2009
              • 2982
              Interested to find out what this could be, on one trip last year the rev needle dropped to 0 and shot back up immediately while cruising on the motorway. It did it twice within 10 mins but hasn't happened again.
