Hi
Had a problem a year ago when charging the carbattery from the engine bay, used a start booster and the car started. Sadly there was a electric spike that took out the airbag unit, checked with Audi here in Sweden and they said is was a faulty airbag unit. Bought a used unit from a car that hasent been crashed and changed it today. The only thing i did was to disconnect the battery and changed the unit. But when i reconnect the battery the light is still on
Do i need to resest some fault codes or what to do?
And another thing, meanwhile I had a faulty airbag unit I changed the motronic ecu with VEMS, are these 2 separate systems so I can reset the fault codes I have on the airbag unit or is it not possible now when I´m using the VEMS?
Regards
Göran in SWEDEN
Regards
Göran in SWEDEN
seems like the old unit was fried and the new "old" box just had some fault code in them. Now it´s working
Worked as a charm in 1-2 days, but now the airbag light is lit for 2 minutes and then it goes out... hmm what to do?
