fitting a WOT BOX
  • jchn_smith
    • Sep 2011
    • 138
    fitting a WOT BOX
    Ok iv decided to put my wot box on the s2 as my golf is a mile away from being finished so might aswell get some fun out of it
    and anyone point me to these wires on the ecu harness or does anyone know were theres a how to for a aby engine
    the wires im after are
    Fuel Injector Drive Signal or Ignition Control Signal
    APP Connect to Accelerator Pedal Position Sensor or TPS
    Clutch Connect to Clutch Pedal Position Switch
    i will do a how to and post resulst if it was worth fitting when i get it in and setup
    cheers john
  • Tony Stark
    • Nov 2009
    • 288
    Whats a WOT box and what does it do?
    • terrybullwon
      • Mar 2006
      • 8782
      Don't you need fly by wire ?
      Chef
      • jchn_smith
        • Sep 2011
        • 138
        no a wot box they give you launch control and full throtle shifts using ingition cut so i will be making boost on launch
        • jchn_smith
          • Sep 2011
          • 138
          one of these http://n2mb.com/ only realy what it for flat shifts but comes with both so ill just be ingoring the launch control feature
          • Acidburn
            • 13459
            might be worth speaking to will20v as he has/had one on his. Can you keep this updated with how you get on as apparently they are brilliant fun and work well.
            • JP
              • 1858
              Only issue I have with them is they are prone to making valves hit pistons on stock clearances due to valve float.
              UrS6 Stroker + HTA3586 =
              • blackS2
                • Apr 2010
                • 455
                I had a wotbox in my aby coupe for 1 year... worked without problems... now thrown out for vems...
                simple to fit... you just need + - and signal of 5th injection valve.
                for clutch you can use original cllutch switch from cruise control...
                signal from throttle is used directly from ecu pin
                negative... you have to cut all 5 cables to ignition coils an put them trough the wotbox
                [__]=oooo=[__]
                  Saw a few people on Audisrs using these on the bi-turbo. I'm sure though you can get this functionality on a stock ecu through mapping according to other threads.
                  Don't think I like the fact all ignition would be going throug the wotbox
                  • jchn_smith
                    • Sep 2011
                    • 138
                    yer i have spoke to a someone about getting it done in the standard ecu but they wont be able to offer it for a while yet and i have it sitting here off my last car so might aswell stick it on for now at least
                    so i have 6 wires 2 go to the ignition earth one goes to ground which is easy but were is the clutch switch located will i have one if i dont have cruise control? what pin is the throttle switch and were will i get + - and signal of 5th injection valve. i ran this on my golf for a year and a bit and it was so much more fun to drive and never showed any signs of doing any harm ill let yous know how i get on once its in.
                    • blackS2
                      • Apr 2010
                      • 455
                      you need ssp 143...
                      [__]=oooo=[__]
                      • jchn_smith
                        • Sep 2011
                        • 138
                        sorry to sound dumb but what?
                        • blackS2
                          • Apr 2010
                          • 455
                          type "dragocl ssp" in google
                          [__]=oooo=[__]
                          • driftin jo
                            • Sep 2007
                            • 2222
                            I think prj has this working on motronic, so no need to cut the loom.
                            • jchn_smith
                              • Sep 2011
                              • 138
                              i mesaged him but he said he wont be testing until the summer and it means i have to send him my ecu and a wot box is cheaper i will be going with his setup though once he gets it up and running
