hi all,im looking for some help please. 1 have a 1989 audi coupe quattro that wont start.it has been stood up for about 6 months.it drove perfectly before it was parked up. the engine now turns over fine but just wont fire,the spark plugs are not sparking when trying to start but when i turn the ignition key to the off position after trying to start it,it gives a hick and tries to fire up and the plugs spark for a second when turning the key to the off position
no spark
Get a hair drier or a heat gun on a low temp & warm up the fuse box (with the cover off).
Check all your fuses & once it's nice & toasty, try it again - could be water in any of the relays (my old fuel pump relay would work if I warmed it up first - I went through a stage of warming it on a radiator in the house before I replaced it !)Comment
No..... I'm just going on previous experience with the same starting problems.
No spark : Check plugs aren't dirty, check leads, check distributor cap/arm, check coil.
The fact that it was running 6 months ago sounds to me like somehting has got damp. Most/all of the above can be warmed on a radiator & then refitted warm which will get rid of the damp. If your taking leads off, just make sure you make a note of which lead goes where on the engine & distributor - get them in the wrong order, and even if everything is ok, it won't start !Comment
