Rs2 ecu in aby whats needed
  • RoadKill
    • Dec 2004
    • 567
    got the main bits
    turbo
    injectors
    outlet man
    intercooler
    got a biger fual pump
    cant think what more i would need
    service tec @ East Kent Audi
    S2 ABY
    B8.5 A4
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    You running ABY ecu?? Just get it remapped for rs2 spec
      I assume that you already have the RS2 ECU with the 3 Bar MAP sensor. The thing is you could start with an ABY ECU and add a 3.0 Bar MAP sensor and aftermarket chip set (e.g. homefries or MRC Stage 3) and get close to 370 crank hp. A straight up, unmolested RS2 ECU will only get you 315 crank hp at best.
      Not sure how the RS2 ECU will react to not having the RS2 MAF.
      You need an OE RS2 or Wagner RS2 EVO exhaust manifold to make it all work.
      • RoadKill
        • Dec 2004
        • 567
        got Wagner RS2 EVO exhaust manifold , done a full rebuild so was going to use an RS2 ecu i got to run it in so i dont have to mess about with the injectors
        S2 ABY
        B8.5 A4
        • RoadKill
          • Dec 2004
          • 567
          so just an rs2 maff ,
          S2 ABY
          B8.5 A4
            Mass Air Flow (MAF) sensor (G70). You might be able to use your ABY MAF:
            Accessed by clicking on the G70 label (lower right) of this:
            • brianb
              • Aug 2008
              • 248
              slightly offtopic but does anyone know what type of resistor is needed to fit to a aby/aan ecu when running rs2 software?i read somewhere it is a 5.3k but isn't the same type of resistor I know of
                prj posted about that within the last 6 months. Search with him as author. (Not needed if you get homefries or MRC Stage 3 software with 3 Bar MAF)
