alternator....or?
  • s2driveruk
    • 12696
    alternator....or?
    at idle, i seem to have a slight 'pulsing' effect on the lighting in the car (e.g. the interior light) and it is just about perceptable on the tail lights too.
    The voltmeter in the car is holding pretty steady at idle but not sure what would be causing this...all seems fine at speed, just generally noticable when stationary.
    I guess could be a tired alternator or bushings, regulator of possibly a poor earth somewhere.
    Any ideas?
    1992 3b S2 Coupe
  • Ian Simmonds
    • Jun 2005
    • 2858
    It's probably the voltage regulator, if it packs up you'll get an uncontrolled output, which on ours set the ABS warning off and the volts meter go off te scale.. Shut it down straight away if it does... You don't want anything 'fried'....
    93 MTMS2 Avant
    • johne
      • Apr 2007
      • 1406
      There's a lot going on for the alternator and its regulator at idle as it isn't turning fast enough to generate much electricity and is trying to keep that 2 volt difference between the battery 12 volts and the 14 or so volts of it's regulated output whilst at the same time the battery wants power to recharge, the car needs power to run and as the alternator tries to turn on it loads the engine which causes the engine to slow down until the ISV can do it's bit.
      In short, it may well just be the way things are or your brushes are getting to the end of their life. Doesn't to me indicate imminent failure of the alternator.
      John
      • s2driveruk
        • 12696
        thanks guys, so it sounds like i might as well pull it out and get it off to a local refurb specialist to get everything checked over/rebuilt.
        1992 3b S2 Coupe
        • johne
          • Apr 2007
          • 1406
          Regulators (which come with the brushes attached) are cheap and easy to change in situ so you could give that a try first if you like.
          John
          • mcandmar
            • Apr 2004
            • 5118
            I would try swapping out the regulator first, but could be a failed diode in the rectifier or winding inside the alternator.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • A1QSHIP
              • Aug 2004
              • 975
              With a digital volt meter set to A/C volts measure the voltage at the battery. With the headlights on & engine about 3,000 rpm you should see no more than 0.5 volts a/c. If more than that you have an alternator diode/rectifier problem.
              HTH, Chris
              "Nulla tenaci invia est via"
              • mcandmar
                • Apr 2004
                • 5118
                I never knew you could do that, nice tip
                • s2driveruk
                  • 12696
                  nice one will check later
                  1992 3b S2 Coupe
                  • s2driveruk
                    • 12696
                    HTH, Chris
                    So just checked and its showing 0.02 so presuming its not that then. Will change the VR and go from there.
                    David
                    1992 3b S2 Coupe
                    • AndyP
                      • 6049
                      David
                      Have you still got a 3B alternator? I have a 15v reg for this that I got from Jamo if you're interested?
                      • s2driveruk
                        • 12696
                        Yeah, I've also got the 15v VR...am wondering if its on its way out though the brushes dont look too bad...bit of corrosion on the tracks in place though.
                        Let me see if i can isolate that as the problem then i may take it from you. Don't remember the stock VR part number do you for the bosch unit? strggling to trace it
                        1992 3b S2 Coupe
                        • AndyP
                          • 6049
                          The one I have came from here:-
                          PSH biedt een wijdt assortiment van starters en alternators. Met meer dan 12.000 types van starter motors en alternators.
                          Sorry, don't know the Audi number.
                          • RS2junkie
                            • Mar 2011
                            • 409
                            • Home: Ireland Current: Bahrain
                            John
                            John,
                            You again may be able to help me.
                            Had my alternator refurbished a while ago (bearings and bushes) and ever since the volts drop below 12v at idle, anything above idle and its back to normal (14v). Would you suspect the regulator ?. Is there anything else it could be ?
                            By the way, have ordered a new fan motor, (they are the same for LHD and RHD).
                            Thanks..
                            Paul
                            • johne
                              • Apr 2007
                              • 1406
                              "Volts drop below 12 volt at idle" - measured by what? If you mean as displayed on the in car voltmeter, then they are notoriously inaccurate.
                              As long as the voltage returns to around 14 volts once you're above idle and the ignition warning light isn't glowing red I wouldn't be concerned but the first step would be to measure the actual voltage using a decent digital voltmeter (DVM).
                              John
