Since the first of January 2012 there is now a MOT failure on a lit or not properly lit airbag dash light. Mine have been shining so bright since I put a bulb in there back in -04/-05 something, but just now resulted in a failed MOT
The big issue is that I can not get any connection with the airbag controller. The other controllers (ECU, ABS, Aircon) works fine in my VCDS-Lite 1.1 (some kind of china copy cable is used).
Any ideas on how I should go about this? Replacing the airbag controller unit? One quick fix that I would like, is some sort of timer relay that will light the bulb up for a couple of second upon ignition. But where can one of those be sourced?
. The big issue is that I can not get any connection with the airbag controller. The other controllers (ECU, ABS, Aircon) works fine in my VCDS-Lite 1.1 (some kind of china copy cable is used).
and their equipment had no problems getting the fault code out. So my "china" copy does not cut it, when comes to the airbag controller. Anyway the errorcode stated something like "faulty driverside airbag igniter".
