Relay Numbers
    Relay Numbers
    Does anyone have a list of relays, the number on them and the part number?
    cheers
    Alex
  • Mikes2
    • 1704
    Most of them are available here via these links although my S2 never had air-con
    This is interactive - click on each relay position for info
    Mike
    http://www.s2-audi.co.uk
      Brilliant, thanks Mike
        MikeS2 (Mike): Indeed your interactive version *is* brilliant. Congrats. I might have to follow your lead for the C4 UrS
        Yours:
        Mine (C4 UrS)
        • Mikes2
          • 1704
          Should have mentioned that if you click on fuse no., you also get a list of the fuses and the diagnostics plugs opens another link
          Mike
            I couldn't get the fuse link to work when, for example, I clicked on "28". I eventually figured out you meant "Click on the 'Fuse No.' Label" and it will take you to a fuse listing. (And it did). Good stuff. I like.
            Can I ask what software you used to do that? Someone took my manual version of my UrS4/S6 Engine Bay Device Map and made live links for the labels (so I never had to learn how to do it). He told me how he did it but I forget the software he used:
            (Click on any of the labels to go to more info about that device):
            • Mikes2
              • 1704
              I don't use any software.
              All the pages are written in raw html.
              You use the map function for the picture. If you know the size of the image, you create hotlinks at the pixel co-ordinates.
              Check the source code or I can send you it over by pm
              Mike
                I don't use any software. All the pages are written in raw html. You use the map function for the picture. If you know the size of the image, you create hotlinks at the pixel co-ordinates. Check the source code or I can send you it over by pm
                Okay, wow. That must have been "fun". (I have captured the source code to use as a guide in case I need that kind of "fun" in the future).
                Thanks. (and congrats on doing that)
                • Nuvo
                  • Nov 2003
                  • 3826
                  You might want to reread this thread Dave.
                    Thanks Nuvo, seems like to day is the day of thread re-reading.
                    http://handy-image-mapper.software.informer.com/
