My radio reception has always been non existant in my coupe, i had replaced the aerial unit and wiring a couple of times with no luck.
So as a stab in the dark i fitted an unamplified aerial unit and coax cable from a Skoda Octavia i broke a while back (i assume mk4 golf etc will be the same). Hey presto, instant radio reception! Fitment to the roof is the same, same connector for the headunit, just no requirement for the white amp wire!!
The aerial itself is longer, so i hope to replace the screw in aerial with an aftermarket shorter one, can anyone recommend one that works? Preferably still twangable rubber rather than a metal one.?
