Please Help - My central locking is not working - Audi S2 Coupe
  • EvenM
    • Nov 2010
    • 184
    • Home: Sweden Current: Norway
    Hello
    I will try to explain the situation as short as possible.
    I bought the car and the central locking was working, on my way home from the deal I decided to try to lock the doors from the passenger side. Then only the passenger door locked, and now the central locking is not working from anywhere....
    The car is a 93 Audi S2 Coupe,
    Where should I start to look?
    kind regards
    Even
  • prj
    • Mar 2010
    • 6308
    Check the system for leaks as a start.
    It can be the pump, or a leak.
    • Smiley
      • Jun 2005
      • 329
      First look: Do you have battery power?
      Try pulling fuse No 12 and back in again (please read on the fuse cover and check the number)
      Open the tailgate and try again (maybe broken wires)
      Do you hear the pump operating?
      '93 Audi S2 Avant panthero black, 412.000km
      '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
      '93 Audi S4 C4 Avant, 260Tkm
      '88 Audi 100 Avant turbo 44Q
      '84 Audi 80 quattro tornado red
      • stanirish
        • Nov 2010
        • 54
        fuse
        Agree - pull the fuse - usually a red 10amp, third one in from extreame right - usually resets alarm and central locking, happens quite often, about once every 3 months !!
        • EvenM
          • Nov 2010
          • 184
          Thanks for all the tips - I will try to pull/change fuse and check the pump tomorrow
          • urS6Tom
            • 773
            What's the easiest way to check the pump? On the S6 it's pretty difficult to get to!
            • EvenM
              • Nov 2010
              • 184
              pulled out fuse, waited.. and put it back in, but no action next step is to check the pump ? i can't hear any "pump noise" when i lock, so maybe that is the problem
              • andy10v
                • 5996
                Was the fuse ok?
                Sold ABY-stock
                • EvenM
                  • Nov 2010
                  • 184
                  yes, it was okey, 10 amps
                  • EvenM
                    • Nov 2010
                    • 184
                    That i dont understand is why the central locking just stopped working because I tried to lock the car from the passangerside.. Maybe a bad wire or something simple? But I dont hear any pump, så have check that out first I think?
                    • andyg plym
                      • Nov 2006
                      • 4646
                      If you find you need a pump let me know I have 2 spare pumps
                      • EvenM
                        • Nov 2010
                        • 184
                        Thanks, I will keep that in mind
                        • EvenM
                          • Nov 2010
                          • 184
                          Where do I find the pump ?
                          • EvenM
                            • Nov 2010
                            • 184
                            • EvenM
                              • Nov 2010
                              • 184
                              I found the pump, se picture above.
                              Now, when I try to lock the doors in only says some "click" noise in the pump! What is wrong ?
