Tacho resistor
  • Tonks4x4
    • Nov 2005
    • 3062
    Tacho resistor
    Hi chaps....
    First time I have had chance to get to sorting this issue....
    Running an ADU engine in an early 82 UR SWB.
    Come to wiring the tacho...
    I have the signal wired to the clocks and it shows idle but when revs increase the needle drops to zero.
    I have some resistors (not the correct rating) but I am on the understanding I use a 2 ohm resistor to correct the input.
    That should work but what wattage resistor do I need????
    Audi Nut!!!
  • Tonks4x4
    • Nov 2005
    • 3062
    Ok chaps....
    Had a brain fart.
    It's a 2k ohm not a 2 ohm
    All sorted now
    Audi Nut!!!
    • Acidburn
      • 13459
      Is this for steve's car? - if so glad he's finally getting it sorted.
      • Tonks4x4
        • Nov 2005
        • 3062
        Yes mate need to spend an hour in the morning and then hope to deliver it back tomorrow.
        Audi Nut!!!
        • Acidburn
          • 13459
          very nice, hope to see it out and about some time soon rather than on his driveway
          • hajbed
            • Jul 2006
            • 146
            • Country: France
            Hello i have the same problem and happy to see this solution.
            2 kohm resistor, but does anyone know how power in Watt? 1W? 5W? 1/4W
            Thanks.
