Windscreen Washer Jets not Working
  • darkhorse1210
    • May 2010
    • 335
    For some strange reason my windscreen washer jets have just stopped working on the RS2. This happened on Saturday when temps were well above freezing.
    I tries them again last night in the garage (again in a warm climate) and they still didn't work. Fluid reservoir is full and the headlamp jets work with the lights switched on.
    Any ideas as I'm clueless with stuff like this.
    Tom
  • Kieron20V
    • Mar 2008
    • 1505
    They could have popped the hoses off if they had frozen solid during the night. Have a look under the bonnet, pipe runs up passenger side of bonnet IIRC.
    1994 URS4 Avant RS2+
    • driftin jo
      • Sep 2007
      • 2222
      Have you tried unblocking them with a pin ?
      Have you tried them with the bonnet open to see if the hose has come off ?
      Does the pump make a noise when you try them ?
      • bikerjim
        • Feb 2008
        • 1028
        I would hazard a guess that the fuse has gone. This probably happened when they were used frozen, it overloaded the circuit and blew the fuse, known it happen on more than one occasion.
        • benntenn67
          • Jun 2009
          • 859
          Please don't use a pin or such, you could damage the nozzle - a nylon bristle or better still compressed air to clear a blocked jet
          Audi S2 Coupe 1995
          VW Passat GL5 (hatch) 1986
          Carrera Subway 8
          • driftin jo
            • Sep 2007
            • 2222
            I don't see how you would damage an S2 nozzle jet with a pin, the jet ball
            is stainless steel not plastic.
            • benntenn67
              • Jun 2009
              • 859
              It's not best practice to clear jets with a pin, as some vehicles have nozzle jets made of softer materials, brass etc
              Audi S2 Coupe 1995
              Carrera Subway 8
              • rynaqui
                • Mar 2012
                • 2752
                • Country: Malta
                Some compressed air will do, could be the pipe may be "pinched" in some places, best to have a proper look at it.
                1996 S2 ABY Silver
                • Drummer87
                  • Oct 2009
                  • 1644
                  • Home: United Kingdom Current: Scotland
                  What fuse number is it??? Too lazy to look
                  • bikerjim
                    • Feb 2008
                    • 1028
                    Not sure off the top of my head Someone will know.
                    • portzi
                      • May 2011
                      • 75
                      Its says on the lid of your fuse box, or is this abit obvious ?
                      • Drummer87
                        • Oct 2009
                        • 1644
                        Lol I was joking about.
                        • darkhorse1210
                          • May 2010
                          • 335
                          Cheers guys, will get these possible causes checked out tomorrow night.
                          • Mikes2
                            • 1704
                            fuse 15
                            Mike
                            http://www.s2-audi.co.uk
                            • darkhorse1210
                              • May 2010
                              • 335
                              Turns out to be the washer jet motor which is near enough 100 sheets including VAT....all that for a squirt of water! Plus that's an MOT fail to boot.
                              Worse things happen
