Fuel Pump Wiring Harness - worthwhile ?
    http://www.034motorsport.com/chassis...t-p-18927.html
    Seems like a worthwhile thing to do, like a relayed wiring harness for ABY headlights if not moving to HIDs ?
    Anyone checked the voltage at their fuel pump before fitting and after fitting of the harness ?
    Thanks.
    G6 Fuel Pump info including relay DIY
    http://www.034motorsport.com/chassis...t-p-18927.html...Anyone checked the voltage at their fuel pump before fitting and after fitting of the harness ? Thanks.
    Once again 034 turned one of my DIYs (from 2004 in this case) into a commercial product.
    The harness and relay probably adds at least 1 V to the supply to the fuel pump, at least for a C4 AAN 091G pump. The 034 kit is probably good value but if you want to do it DIY, it will be slightly less money:
    Part of this fuel pump post:
    • andy10v
      • 5996
      Dave has a great write up as usual;
      Easy enought to buy a relay and wires yourself as well.
      Sold ABY-stock
      • andy10v
        • 5996
        And is faster
        Sold ABY-stock
          And is faster
          Only slightly. I just got up. 6:35 AM here. (okay 6:45 AM now)
          • andy10v
            • 5996
            You are enthusiastic!
            I would still be in bed at that time, its lunch time now for me!
            Sold ABY-stock
              Happy new year and good health to you Dave.
              To hell with the few philistines.
              • JP
                • 1858
                Kits are only useful if you have no electrical know how. It is real simple. Permanent earth battery to fuel pump. Then use a fused relay from battery +ve to pump using original loom to switch the relay.
                Changed voltage from 12.2 to 14.4v at the pump by bypassing the old wiring in the car resulting in no lean spots at the high end of the rpm range.
                UrS6 Stroker + HTA3586 =
