RS2 : How hard is it to make the dash board lights brighter
Bulbs are really easy to remove they just pop out once you turn the bulb housing
There are a few people who have tried the led route with mixed results, some say its great others disagree as although brighter it doesn't illuminate the whole clock face, just the area it's in so at night some areas of the dials are dark
At least on the C4 UrS4 and UrS6 the solution to that problem is simply to replace the factory 1.2W bulbs with 2.0W bulbs. Takes minutes once you get the cluster out.
Dave,
Agreed, but do you or others find any adverse effects to the "white" gauge faces, such as peeling due to presumably slightly more heat from the slightly higher wattage bulbs.....Just asking.
Thanks.
Dave, Agreed, but do you or others find any adverse effects to the white gauge faces, such as peeling due to presumably slightly more heat from the slightly higher wattage bulbs.....Just asking. Thanks.
Going to 2.0W bulbs from 1.2W bulbs has been done here in the UrS community since the late 1990's. I haven't heard of any issues with any (grey, they aren't white in a C4 UrS) gauge faces. Okay maybe once but it is very uncommon.
Thanks for reply. Agreed re the off white colour. My post edited. Apologies for the error.
Sorry about that. Just needed to make sure we were talking the same thing. Oddly (?) I believe the RS2 gauge (clock) faces *are* white, as opposed to S2 and UrS4/S6 grey.
Back on the gauge face peeling, I can only remember one case being noted on the three UrS4/S6 forums I am on (since 1998). Might happen but it is either not reported or it happens to non-forum enthusiasts. No idea.
