Factory immobiliser has stopped beeping
  • Colesy
    • Feb 2009
    • 2982
    I have an aftermarket alarm installed alongside the original factory immobiliser that beeps when you lock the car. Today I noticed that the factory beep has stopped beeping.
    This is after having the car in lots of pieces so I was wondering if I might have dislodged something under the bonnet? Or under the rear seat? The aftermarket alarm still works exactly as it should.
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Mine doesn't beep but I think it's the factory 1 button alarm, not sure which that would be but it does make a funny sound when I lock it
    1996 S2 ABY Silver
    • Colesy
      • Feb 2009
      • 2982
      The beep I mean is the sort of muffled beep type noise that you get when you lock it. It's a funny noise that I've always liked!
      • andyg plym
        • Nov 2006
        • 4646
        Is it the horn in the emrear quarter panel ?
        • shaun5
          • 1610
          As andy has said, there is a horn (ive got one ) in the rear quarter (dont know which side) it could be a wire off or horn fault.
          Is the factory alarm controlled by the central locking pump? could be that at fault.
          • Colesy
            • Feb 2009
            • 2982
            Cheers guys, I had the n/s rear door card off fixing some speaker wiring so maybe dislodged a wire. I'll have a check tomorrow.
            • bluequattro
              • 2960
              Passenger side quarter
              I took one off a cab last week
