998 vag 151 alarm
  • RoadKill
    • Dec 2004
    • 567
    998 vag 151 alarm
    would this stop the fuel pump priming if it was not working right ?
    service tec @ East Kent Audi
    S2 ABY
    B8.5 A4
    What vehicle are you talking about. As far as I know none of the UrS (S2, UrS4/S6 and RS2) vehicles throw any direct codes related to the fuel pump.
    • RoadKill
      • Dec 2004
      • 567
      ok it my S2 been off road for 2 years doing rebuild , put a bat on it and its not cracking over and theres no fuel pump priming , have to see if theres a box for the toad alarm could not see one when i looked
      S2 ABY
      B8.5 A4
        If it is an ABY S2, then as far as I remember, it is like the AAN in the UrS4, there is no pump priming with the ignition key on. The fuel pump relay is not triggered by the ECU until the ECU gets a signal from the G28 engine speed sensor that the RPM is > 13.
        J17 Fuel Pump Relay info:
        G28 Engine Speed Sensor info:
        Reasons why your AAN (or ABY or ADU) isn't starting:
        • RoadKill
          • Dec 2004
          • 567
          im a right div put the swich wire on the rong peg , just need to sort the ground out now its only getting 2v when turning over ,
          thanks for the help
          S2 ABY
          B8.5 A4
            im a right div put the swich wire on the rong peg , just need to sort the ground out now its only getting 2v when turning over , thanks for the help
            2V to starter = less than 13 RPM cranking speed = no fuel pump relay energizing by the ECU = no fuel = no start.
