Help With Battery Drain
  • bilko0795
    replied
    Originally posted by Mikes2
    Sounds like there's possibly a problem with the stereo or the live feed you are using is being used by something else.
    0.8A will flatten the battery. A boot light permanently on will draw 0.3A
    There isn't normally an ignition switched feed on the S2. Where are you sourcing the permanent feed from. It should already be present in the radio iso wiring.
    I have found another wire behind the stereo that was also perm live probebly the one you are on about, so i connected it to that and checked the drain and it is showing the 0.8 well i left the car for 8 hours while i did my shift took some jump leads just in case but didn't need them car started with loads of power in the battery, Will have another dig around on the w/end to find where the drain is coming from.
  • Mikes2
    replied
  • Dybro
    replied
    Originally posted by bilko0795
    Right i have been checking the circuits and i think i have found the culprit when the stereo is connected to the blue wire on the ignition switch it's drawing 4.78 and falling steady when you disconnect the blue wire there is zero drain, i found another perm wire and connected the red from the stereo it's drawing 0.8 5 is this an acceptable draw on the battery or still to much.
    800mA is way too much!
    My UrS4 has less than 10mA total - my clarion radio draws about 4-5 mA
  • bilko0795
    replied
  • bilko0795
    replied
    Anyone know what the G4 selector switch is and where it is ? Don't think it's the interior lights they go off when you close the door's there is no other light illuminated in the car exept the clock the radio is also not on. I am wondering whether it could be the anti-theft thingy as i have been ripping the after market alarm out and i also changed the ignition switch for one with the correct Colour wires but this did the same thing when i had the other ignition switch fitted. I have also taken out the relays no clicking detected.
    replied
    Right found the B-----d fuse no 4, 44.9 milli amps and dropping steady. would fuse 4 be ignition or most likely interior lights what's the best way to about finding the culprit.
    This help?
  • Pat D
    replied
    Might pay to check if any relays are staying on with the ignition keys out. Slowly pull them out of the socket one by one and listen for a clicking sound.
  • Pat D
    replied
    I think the fuse description is on the fuse panel cover?
  • bilko0795
    replied
  • bilko0795
    replied
    what number is the fuse for ingnition? i cant find it on the ECU casing? im sure its the ignition switch as ive been under there alot recently
    replied
    I'm thinking your ignition switch is broken inside and not switching off properly..
    replied
    4 Amps would be lights on, heater fan, or ignition on, that's a big drain. When the meter is reading 0.00 on the 10 Amp scales switch it to 200m (one click anti clockwise) so you can see the milliamps.
  • twoqu
    replied
    Think you might have misunderstood the instructions.
    You need to remove the battery negative terminal completely. You then connect the multimeter leads between the negative battery pole and the negative terminal. So thats one multimeter lead on the bare battery pole and the other on the negative terminal lead. In series means between!
    I use a spare battery terminal to do this test as that way you can leave it connected whilst pulling the fuses!
  • Pat D
    replied
    Pull fuses out one by one until that reading falls close to zero. Then you will know what circuit is causing the drain. 4 amp drain will cause the problem you're describing
  • bilko0795
    replied
    This is the setting I have it on
    This is what was first read when I connected the wires
