Lights: Normal Beam switching off on highbeam
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    i did the same as fendent did in this thread and i just moved the thick yellow wire into the 56b -> 8 in the plug and the i closed the plug at it and now it work pefectly with out any problems
    the plug is open able and when u move it arround 3mm then its able to pull the yellow wire out and relocate it into the 8 port.. and if this picture have some difference wires its because for 80 typ 89 16v with regular headlights h4
    • s2carlo
      • 252
      Originally posted by kninio
      http://www.s2forum.com/forum/showthr...ghlight=wiring
      Well, today I took the time to have a closer look at the connector and it's wires on the lightstalk. It turns out it looks a lot like the one Martin showed (see below) but: Green/red & green/black are inverted and the brown/yellow wire is on pin 8 instead of pin 1.
      I now put in a bridge between pin 8 and pin 7 (as pin 8 was already used) and the dipped beam stays on, all looks OK.
      However I would now like to know what is the brown/yellow wire for and does it belong on pin 8. If I know what it's for I can try it on pin 1 and if all stays working I can loose the bridge and put the yellow wire in pin 8.
      I can not find the brown/yellow wire in my schematics, anybody any idear??
      Thanks in advance
      Carlo
      No power, no glory!
      S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
      • kninio
        • Aug 2004
        • 641
        if u have voltage tester.. then try to check which free source can give electric while the high beam is on and then stick ur yellow thick into it.. i have this brown yellow in this plug which i show in the pic also in the pin 8 i taught its like that because it wasnt for s2 or v6 car but now i am confused.
        • s2carlo
          • 252
          Anybody any idear what the brown/yellow wire is for that is on pin 8 (or 7)??
          I can not find it in the schematics I have, anybody any idear??
          Thanks in advance
          Carlo
          No power, no glory!
