My instrument panel temperature was not working always, it was constantly going up and down, so I removed the cluster and cleaned the two contacts and now it shows stable and consistent temperatures. The problem is that those readings are around 10 degrees higher then what they should be. I have a 70 degree stat and a fan switch that kicks at around 80 but when the car is stationary the fan kicks in at 90 on the cluster. When stationary the cluster shows 90-95, when cruising the temp drops and stays stable at 80, but it should be 70 because of the stat.
I measured with an IR thermometer and it also confirms that the cluster shows higher temps. How can I confirm that my sender is sending the correct resistance? Does someone know any test values? Thanks!
