Window/sunroof fuse location
  • mac2226
    • Jun 2008
    • 1289
    Hi every one I own a s2 coupe aby and I've been changing the sunroof interior and now They have stop working replace the relay as I thought it was that at first and now I need to replace the fuse but can't find it could some one tell me it's location
    Originally posted by mac2226
    ...now I need to replace the fuse but can't find it could some one tell me it's location
    I thought it would be here (below) but I don't see it.
    • mac2226
      • Jun 2008
      • 1289
      I'm not Very good with electrics but you would thought it was in fuse box listed
        ...They have stop working replace the relay as I thought it was that at first and now I need to replace the fuse but can't find it could some one tell me it's location
        You need to go to: http://s2central.net/main_frame.html
        Select Technical Data
        Then Electrical Systems
        Then S2 Current Flow Diagrams
        Then scroll down to Audi Coupe S2
        Then select, for example, MY93-ABY-C
        Then scroll down to D37 Sliding Roof and click to get the pdf. Shows an S12 fuse and an S83 Thermo fuse. S83 might be on the Auxiliary Relay Carrier under the rear seat
        Also check out B30 - Electric Windows (2 dr) - which shows an S43 thermal fuse on the Auxiliary Relay Carrier under the rear seat.
