All Dashlights Failed
  • All Dashlights Failed
    any clues on this one, guys?
    took my car out the other night & no dashlights at all. Main dash and auxiliary gauges all not working. (Warning lights still worked). Checked the no. 12 fuse (15 amp) & okay. Dimmer knob made no difference either.
    All bulbs were replaced 2 months ago.
    Where shall I look next for faults? It's no fun driving in the dark not knowing your speed!!
    Try removing the bulb holder/switch assy from glove box(this is part of the same cicuit), this sometimes can go short circuit. Also check a 5A fuse, I think it might be no. 11 or 15, though I can't be sure. The fuse box will help identify the one you need to check/replace.
    Nuvo
      When mine wasn't working it was the dimmer rheostat which failed - see here
      Now RS2'less
      '99 VW Passat VR5 Sport
        thanks guys - had another look today - this time in daylight.
        the fuse for the instrument cluster lights is no. 14 - 5A.
        Also checked the glovebox light - bulb had blown & switch didn't work, meaning light used to be on whether glovebox shut or not.
        All sorted now.............except airbag light - I guess it needs resetting after I removed fuse no. 12 which I guess covers dash warning lights..
        ready for the next problem now.................
          You're welcome!
