[SIZE="6"][/SIZE
Hey folks my thermal fuse in my 1990 coupe has blown yet again does anyone have any ideas for why this might keep happening , also just been upto maplin for a new fuse and they gave me a choice of about eight with different temperature any clues anyone..
[SIZE="6"][/SIZE
Which thermal fuse is this? I remember asking about thermal fuses and the answer was there aren't any.
Can you post a photo of the problem fuse?
In the meantime, this link shows the diagnosis of a failed thermal fuse on a C4 UrS4 (the injector fuse in this case):
[SIZE="6"][/SIZE
I assume you mean the thermal fuse on your fan speed resistor pack? A thermal fuse around 110/120 degrees will do and the reason it keeps blowing is because your fan motor is partly seized and needs lubricating.
